Stator Issues
Monark80
I have a 1980 Mercury 70 hp outboard serial # 5651206. the stator is a CDI 174-545K1 which has a blue/white and a red/white wire assuming that is for low speed and high speed. Both of these wires are going to a ground (don't think this is right). After looking at 2 different repair manuals neither shows these 2 wires for this model. Wondering if I have the wrong stator or can someone tell me where these 2 wires connect....:confused:
carholme
Monark80
Re: Stator Issues
Gerry, Thanks for your help this is the way it is wired..... just don't know why I have had to replace the power pack, stator and trigger twice and have less than 20 hrs on motor since first replacement....:confused:
carholme
Re: Stator Issues
What is the history of the problem and who replaced all of the electrical components, was it yourself or a shop? Is the engine running now?
Gerry
schematic
Re: Stator Issues
I would be very surprised if they all needed replacing.
Unless of course, someone was powering up the ignition system components with 12volts....
Monark80
Re: Stator Issues
the shop replaced em the first time and I replaced em the second time.......went by the wiring instructions per shop manual... Motor is running fine right now just loosing faith in it to get me back to the dock
canoemang
Re: Stator Issues
If it is running fine for you then run it..
faith in a motor will come in time..
Monark80
Re: Stator Issues
will not give up on it been with me for years.. we have caught many fish together
