Re: Stator check
Well a miss and a loud bang, like hitting a log, are 2 totally seperate things. The way you descrbe it now it does sound like a clutch dog. The lobes of the dog are precisely machined edges, and when these edges start to wear or round, and you increase the rpms, the pressure of the gear against the dog forces them apart, causing it to jump out of gear, then the shift cables tension forces it back in, giving you the sensation that you hit something.
This is usually caused by improper shifting by the operator. When shifting, ensure that you make deliberate quick shifts. Slowly shifting into gear causes the edges of the dog and gear to bang against one another, wearing them down.
Testing the prop to be spun is quite easy. Simply draw a line across the hub and prop, or use the cotter pin as a center line, run the motor until you hear it "slip", then check if the lines are askew. If they are no longer lined up, the prop will need to be re hubbed, much cheaper than buying new. Or if the prop is in poor shape, may want to invest in a new one.
You may very well have more than 1 demon that you are trying to chase.
