Stator check?
tbjtib
Hi,I am trying to check a stator on a 1980 inline 90 merc. I checked with a voltmeter while running, and the low speed checked good and the high speed was in in spec except polarity was reversed. Does anyone know if this is right or how to correct? Motor runs good until it gets on plane then begins surging. fuel,carbs are good Thanks,Timb
lonewolf5347
Re: Stator check?
timb:i would check the stator with a ohm meter. hi @ low side to see if resistance is the same.not running disconected from switch-box
petryshyn
Re: Stator check?
timb<br /><br />I see that you've posted this question several times. Try keeping it to one post and you'll get better responces when everyone knows the full history :)
