A 1997 Mercury OB 150HP Model# 1150422TD <br />Serial # 0G530666<br />This engine will cold start and warm start fine most of the time but sometimes:<br />There is no reaction when the key is turned to the start position. It reacts like the battery is totally dead - which it's not. <br />Other pertinent info when this occurs:<br />1- You can try starting it again and sometimes it will start and sometimes not. Eventually it will start.<br />2- Gauges all fall to zero when the key is turned to start.<br />3- Usually you will get mutiple beeps.<br />4- Sometimes all guages go crazy after start.<br />5- Ignition switch, kill switch, engine control, including neutral safety switch and battery are all new.<br />6- ALL engine and battery cables have been thoroughly cleaned.<br />Are the voltage regulator(s) or the starter solonoid possible culprits<br />Please help with this gremlin - we are at our wits end trying to solve this problem.
