Starts & runs only after starting fluid.
HMS57
1989 225 VRO Evinrude,
Bypassed VRO & pretty much feel that we did it right, installed electric fuel pump & seems to be working fine, BUT motor won’t start and run w/out first using starter fluid. After that it stays running. It’s almost seems like it’s not getting fuel during the cranking but once it’s starts on starting fluid for a few seconds the fuel picks up and motor continues to run.
Any input will be very appreciated
Thanks.
jimmbo
If you want that engine to live very long, deep six the starting fluid. Ether is very effective of washing the oil off of the bearings as it passes through the crankcase. and being self igniting, it could also ignite during the crankcase compression stroke.
What is your starting procedure? Squeeze primer bulb, set high idle, engage choke/enrichener, turn key?
What are the compression numbers? Leaking crankcase seals can be a cause of hard starting.
GA_Boater
Welcome aboard.
Are you priming the fuel system by squeezing the bulb for cold starts?
Starting fluid isn't good for 2 stroke motors because it has no oil.
HMS57
Thanks guys for your replies. I told my son to go through the shop manual for the proper starting process. I also mentioned to him that we need to make sure that the cabling from the console to the motor are properly adjusted and that the choke with the ignition key is also operating properly.
Thanks Again
flyingscott
First thing I would do is get rid of the electric fuel pump thats asking for problems. Install the correct double pump. If you decide to keep the electric fuel pump ( bad idea) do you have the primer plumbed into the fuel line.
HMS57
I believe that when he installed the electric fuel pump the bulb was removed only because he was thinking that the electric pump would make up for not having the bulb.
GA_Boater
Most electric fuel pumps can't pump air efficiently, which is what you have until the either the bulb fills the pump or with the starting juice, the motor runs long enough for the pump to fill and start pumping fuel.
Add a bulb and dump the electric pump, if for no other reason than safety. 2 strokes don't have oil pressure to disable the pump and if something happens, the pump will run until the tank is empty - Not very safe cuz that gas is going somewhere and it isn't good.
