Re: starts only with starting fluid
you don't want to use starting fluid unless it's an emergency, you will not have sufficient lubrication and can damage the engine this way. problem is probably carb related but it's worth checking compression first. Starting fluid is designed to require very little compression. If comp looks fine I would remove the carbs and tear down to clean and reset the mixtures and idle to factory. You must be getting spark or it wouldn't run at all.
