What could be causing my motor to fire right up on the muffs in the driveway but require significantly more cranking once it's in the water? I understand there's increased back-pressure in the water but is there anything else I should be looking at? Motor is a '94 60HP Johnson with 115 PSI compression across the board and new spark plugs that clear a 3/8" gap. Once started, runs like a dream.
