starting
rtuttle200hpj
1992 200 hp johnson was running 5-1-3. tried to start 9-1-3- will not start. starter not spinning faster enuff on first 2-3 starts then starter will spin until let key go. ck battery ok. ck all connections ok. have a small leak at priner solinoid . carb over hauled 1 yr ago. i have 2 200 on a 25 ft boat the other one started right up. can the leak be problem. can a bad key switch<br />cause motor not to start. will ck spark to plug 9-13-03. what else can i look for or do to get my motor going.<br />looking forward to responses.
Hooty
Re: starting
Pull the plugs and inspect them. If they're wet, you've probably got no spark. If they're dry, you've got no fuel. If they're real wet, it's flooded.<br /><br />c/6<br />Hooty
nstevens
Re: starting
Do you get any exhaust fumes at all when trying to start it? <br />As Hooty says - pull the plugs and report back.
rtuttle200hpj
Re: starting
hooty and legin - thanks- its was flooded - dont know why. tilted motor up a while then down and tried to start until ran battery down . on second battery it started up. been running all week end- thanks again--does any one know how to contact cdi( a company ??) for parts I saw a power pack for $94.00 for a 200 johnson- they are $140 to $200 in mobile al. i needed a trim tilt motor for my 200 john. it was $250. found one for $120 but hope cdi or others dont have it for $90..
