I have 115 Johnson 77yr. I have good fire. plenty of gas, and Will still not Turn over. I have just replaced the H2o Pump got it in now, doesnt want to Run?
I assume that when you say turn over you are refering to the engine starting?<br /><br />As Turn over is what the starter does to the engine.<br /><br />If it appears that you have spark and fuel the engine should start...unless the engine is not able to compress the fuel/air mixture. Or you have old gas.<br /><br />Is the choke operating? Closing all the way?<br /><br />If not you will just get the engine to turn over and fire...not run<br /><br />TMD
Badfingers.<br /><br />You need to supply more information.<br /><br />Also, your signature is gross overkill. Could you tone it dawn a bit?<br /><br />Thanks.
Sry about the Sig my Game Sig I take it off Sry M8, Ok I found it On THe Arm Lever Arm underneath the Fly that little Bushing is Damaged cause it to not in Gauge. I Gotten VERY LUCKY on this Motor She not Damaged Cause of the H2o Pump.
