1977 25hp Johnson. Unsuccessfully attempted to start after sitting for winter. Noticed carb was flooding. Removed carb and noticed one of the four screws holding the 2 halves of the carb together was missing. Took carb apart and cleaned with carb cleaner. Installed carb and now I'm not getting any gas to carb. Fuel pump is pumping fuel. Sprayed some gas in carb and it ran for a few seconds, so I'm pretty sure the carb is just not getting fuel. I removed the hose from the fuel pump to the carb and it is clear. Can anyone tell me what I need to do next with the carb to allow fuel to it. When I took the carb apart to clean it, the float moved easily. Any adjustments or does it sound like I need a rebuild? Thanks.
Jim
Jim
