Re: starting trouble
Like Loco said, it sounds like the starter is getting just enough juice to spin, but not enough to turn the engine over. Make sure your battery is good and has a full charge, check all electrical connections from the battery up to the starter. Don't forget to check the block ground.<br /><br />Or, you might have a stuck piston or some other internal problem that is preventing the engine from turning over. Try taking the plugs out and turning it over by hand to check for this, or using the rope starter if equiped.
