255 amberjack
- Jul 28, 2010
- 12
Hello all, i have a 1983 mercruiser 5.7l 350 with an SE106 outdrive on it. My problem is this: My rochester 4mv carburetor is not working properly, when i have the boat at the house on the trailer i start the engine up and warm it to make sure everything is running smoothly before i take it to the ramp. i hook up the boat and drive to the ramp and put the boat in the water and then the thing wont start it will turn over anytime i try but wont start so i have topull off the flame arrestor and stick a screwdriver in the secondary air valve after a few cranks it will start right up pull the screwdriver out and it will idle fine anytime i shut the engine down if i want to start it back up i have to perform this little trick. i bring the boat home and the next day go out and it will crank right up. do i have a choke problem i noticed the choke thermo coil is not connected to the carb since there isnt one and my P.O.S. Seloc manual does not tell me where it should be on the carb, wondering if it's supposed to be on the engine somewhere. i'm thinking maybe the engine is warm and im trying to start it while the choke is stuck closed just looking for advice on whether this will cause that problem.
