starting problems
know nothing
Have 94 Bayliner Jazz will not start with key. Changed switch and kill switch, also changed selinoid, still will not start. Will start by jumping selinoid but will not shut off will key. Does anyone have an ideal, if so HELP PLEASE.:eek:
kend301
Re: starting problems
Replace the key switch , they had a problem with them , Standard 6 prong, push to choke switch available at any boating store . If this does not fix it post up but I really think it is it as long as your definition of starting is engine running. See the top post here for some important info about starting these boats "Sport Jet Basics"
know nothing
Got new key switch and still will not start without jumping silinoid and will not shut off with key must choke to stop.Any suggestions?
fordworker
double check switch wiring. also give more details, was it working well and stopped, or did you aquire the boat in this current condition?
kend301
Could be the boat harness , do you have a boat manual for your boat ? If not you will need clymer manual # w815 to see the proper tests for the switch and harness .
Oode
I'm willing to bet you have some corrosion on the wiring harness connector on the motor. Look behind the engine and find a black barrel connector, sometimes snapped into a sort of hook snap wire on the back side. If you unhook from the back then unplug this, look at the pins and sockets and see if they look clean. If so, move on.. if not, clean up the contacts, then do yourself a favor and put some dielectric grease in there and plug it all back together...
If that doesn't do it, best to get the manual, then you can ring out the wires to figure out which is not connecting up....
kend301
You can order the manual from the parts store on this website .
