Starting problems Johnson 70hp 2001
arvendal
I have a Johnson 70 2001 (BJ70VLSIS) and experience problems when starting after the engine has been off 3-4 hours.<br />When I pump the primer bulb it never becomes really hard (not a hard as the oil bulb). The engine is completely dead until I raise the idle lever some. Then the engine starts and appears to run - well really bad, like it has too much fuel and that the different cylinders aren't operating together. But after a minute it's ok again. And after that it's no problem shutting it down and restarting direct.<br />I've searched on this site for similar problems and some ideas has been that to check the valve in the gas pump.<br />Can the not-so-stiff primer bulb be an indication of the problem?<br /><br />Best regards,<br />Mats
roscoe
Re: Starting problems Johnson 70hp 2001
Yes, the primer bulb and back flow valve are likely the problem.<br /><br />Its time to try a new fuel line.
JB
Moving to Johnson troubles.
arvendal
Thanks for the reply,<br />but how do I check the fuel line - is it as simple as just checking for fuel leakage?
