A couple of weeks ago, I wrote in about my starter that would work fine the first time you would turn over the key, but would not turn the motor over if you shut it off and tried it again. After it would sit a little while, it would work fine. Anyway, I checked all connections, wires from the battery, starter bench tested, battery tested, and solenoid all checked out. It turned out to be the cheap 2 piece bendix on the starter. It is designed to not turn the motor over if it felt to much resistance so to not damage the flywheel teeth. Replace the bendix and all is great! Thanks for all the suggestions nd help!<br />Craig
