ParisDakar
- Feb 21, 2002
- 3
I have a 1979 Johnson 150 V6 that is very difficult to start. Takes at least 30 seconds of cranking with choke on, lever up, and the fuel bulb pumped hard before it kicks over. I've been using a shot of starting fluid to get it to fire to avoid killing the starter motor. Once warmed up, and even after not running for several hours, starts easily with lever up, maybe a spot of choke, but nowhere near as stubborn as when stone cold. Tilt engine up for shallow water idle and it gets weak and sometimes quits. Also hesitates when opening the throttle, which only goes away when fully warmed up. Sounds like lack of fuel, so what to check? Any thoughts? Thanks.
