fisher91blue
- Jul 23, 2014
- 30
1992 4.3L GEN II, 2 BBL, Thunderbolt IV
Recently, have had some issues that I would like to try to resolve while boat is in water for the season. Trying to determine if I should start with fuel, choke (air) or distributor/plugs/wires? Any help from the experienced members would be greatly appreciated.
Symptoms:
1) with fresh gas (albeit only a few gallons) the motor stalled multiple times moving from launch to dock slip when I advanced throttle
2) idles rough and seems low, around 350 RPM
3) at times, when engine is warm or when cold, attempting to start, will crank but doesn't fire, then eventually fires up
4) sometimes with throttle in neutral, when key turned I hear 1 single "click" then nothing. after I wiggle, it will turn over normally
4) noticed some hesitation and surging at low RPM speeds, like travelling through "no wake" zones
I have slightly adjusted idle at carb to increase RPM, fueled 2x since first noticing the issues with no apparent improvement. Batteries are tested regularly and strong. Both batteries on solar trickle charger when boat is not in use.
Open to suggestions for a starting point so I don't try to chase too many rabbits at once.
Thanks
Symptoms:
Thanks
