Re: starting motor out of water
Is this the first time you have used the muffs on this motor ? If,not how was the delay last time?<br />On this big banger, you most likely have a thermostat or 2 and the pee-er won't start until it warms up a bit. It is normal for water to come out everywhere around the L/U during flushing.<br />Run it with 3/4 pressure for a couple of minutes (No longer) If no pee, push some wire up the Pee tube, as it may have some gunk in it. If there is still no pee, the impeller may have de-laminated and it's time for a WP service, which should be done every few seasons anyway.<br />BTW Never run without water as the impeller can de-laminate from the brass bush.
