Starting issues
Gavinblady82
I have a 25hp 4 stroke mercury that I recently replace the fuel pump on. Cranks and runs great when I get to the lake, but after shutting it off to fish, will not start, only turns over. If I disconnect the fuel line from the motor, it seems to have plenty of pressure on the line. I can bleed the pressure and hook it back up and pump the ball and it will usually start again. Any suggestion on what could be causing this issue? Almost seems like the fuel system is vapor locked
