Starting issue
Lukiebs
I just got a 1995 Johnson 90hp and I got the guy i bought if off to turn it over for me and it started fine. Got it home and hooked it up to the old battey that the other outboard ran off and it would not turn over. when i turned the key the alarm sounded to tell me it's ready and the trim works so i go and try to turn it over and nothing except for a tiny bit off smoke off the battery terminals and it arched on the battery. Any ideas??/ Could it be the battery is just too old or to small. It was used to start an 78 Johnson 115 before. Thanks
jonesg
Re: Starting issue
The battery terminals are loose or dirty.
If it has thumbscrews replace them with nuts and use a wrench tighten them TIGHT.
tashasdaddy
Re: Starting issue
99% weak battery, and loose terminals.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
Lukiebs
Re: Starting issue
Cleaned all the terminals and hooked up the old battery, Got a couple of clicks out of the starter then nothing.The battery just smoke a little of the negative terminal. I think the battery has had it. Will go get a new one to try it out.
JB
Re: Starting issue
Did you clean both ends of both battery cables... and the short one from the solenoid to the starter??? Did you check the cables for weak/swollen places??
If you are getting a hot terminal a large amount of current is flowing. That doesn't sound like a bad battery. It could be a bad starter.
Go to the Engine FAQs Forum and do the starter circuit testing in "Outboard won't start".
Let us know what you find.
levittownnick
Re: Starting issue
If you have a hot or sparking terminal, you have a bad connection at that terminal. Don't look any further.
tashasdaddy
Re: Starting issue
connections have to be tight, use a wrench or pliers. not hand tight.
ezeke
Re: Starting issue
You may need to replace the battery cables. They tend to corrode inside the sheathing over time; you can usually find the weak spots by the heat that the resistance generates.
You can also isolate starter problems with a voltage meter by conducting voltage drop tests.
Lukiebs
Re: Starting issue
Thanks for the replies. I'll get out my other battery cables and i'll clean all the terminals and will see. Didn't think of cleaning the terminals to the starter. Put a volt meter on the battery and its down to only .05 amps so it's dead. Will get a new battery any way cause redoing the electrics as part of my restoration. will post after i try it out again.
Lukiebs
Re: Starting issue
Also what is frustrating is the guy I pick it up from cranked it over first time when he had it hooked up to his truck. Thats why I'm thinking it battery. I'm using all the same cables but the only thing different is the battery.
