Greetings fellows,
I have been working on a QD-16 and after much fuss I cannot get the bloody thing to fire. I have replaced the entire ignition system, including wires plug boots and new plugs. I had a leaky pressure tank and so, I have rebuilt the tank and the leaks have been taken care of.
I also installed a new carb kit.
The problem is that I am not getting fuel from the carburetor to the combustion chamber. I have fuel to the carburetor. To test my theory, I did pull the plugs and sprayed fuel into the cylinders and then replaced the plugs and she fires on the first or second pull.
This engine was squeaky clean when I bought it so it's not like I had to evict insects and grime out of it. Needles are set at standard initial settings.
