I accidently ran my '95 9.9hp with the fuel hose disconnected from the tank Last year I did the same dumb thing. It took me about a half hour to get it started last year and today I didn't after a good hour of intermitently trying and pumping the bulb every time I could. I use this motor almost every week and it always has started easily and run fine. The first time I ran it out of gas was right after I bought it. Today was the second time. I have the owners manual for a '99 that I downloaded from the Johnson site and it seems pretty close to my '95 on the general things. The only thing I could find in it was that the priming bulb should be pumped with the discharge up. Mine is kind of lashed to the back of the seat the tank is under. Could this make that big a difference? The bulb gets firm pointing down and has good pressure at the motor, it will squirt when disconnected from the motor. Would I be better fo spinning it with the spark plugs pulled till I see some gas/oil spitting out of the cylinders? Or is there something else I should do? Any advice would be greatly appreciated.
