I was recently told that if I start the engine with the out drive tilted up I would be stretching the lower shift cable.<br />I just had to recently replace it.<br />When fishing in the shallows I am moving in and out with the out drive tilted up, starting and re-starting in the up position. I been told that is is wrong and that you should always start with the engine with the outdrive in the down position to avoid strectching the shifter cable.<br />Any comments?<br />Thanks
