The Fifth Lady
- Jul 29, 2007
- 8
Hello! I have an 87 I/O OMC 5.7 with 350 block. Initially, a problem surfaced when she stalled (going from reverse to neutral) and would not restart after she had been running for an hour. I thought she was flooded and finally started her and got home.
A few days later on the next session, I could not get her started. My efforts put a strain on the battery,but finally got her started. I began to think that this was a float problem and she was getting too much gas and flooding. We tapped the carb and thought maybe problem solved. I let her run for a half hr, then off and she cranked right back up w/no issue. Or perhaps this was a choke issue. In any event, I figured a Fuel filter would not hurt, w/ the Ethanol and water issues I hear about.
2 days after that on my next session, I replaced the Fuel Filter and noticed a good bit of water in the filter. I had a hard time getting her started and figured it was the water left in the line/ carb. My start attempts put a strain on the battery and I ended up getting her started with a Jumper box. I ran for 30 min's to get a little charge back.
2 days after that, my goal was to finally take her out, run her for a while at 4k rpm's to get a charge and run the fresh fuel and Star-Tron I added into the tank. After 3 cranks and my buddy manually holding the choke open a quarter inch, she fired up. (I had him mess w/the choke b/c before even cranking, we removed the Arrestor and choke was open). I ran her for an hour trip, and noticed that both my dash Meter and GPS noted the Batteries (2 w/ 650 Cranking Amps) were at 14volts. Then entering a marina, she stalled when going from reverse to neutral. Trying to start her in neutral was unsuccessful and so was pumping. After only 3 cranks or so, I was surprised that my batteries were very low/done. I got a tow to a slip, then proceeded to try her (w/ a Jumper Box) a few times without success. We even used some Starting Fluid. After letting her sit a bit, she finally started and got us an hour back to our home marina.
Backing into my Slip, she stalled again going from reverse to neutral. I tried to start her in neutral immediately and got nothing and the batteries again seemed weak. 20 minutes later, she fired right up.
Every time I think I am onto the root of my issue, something else happens and I an CONFUSED! To summarize, my issues seem to be A) Cold Start B) Warm Start and C) Battery (shouldn't the alternator work fine charging after an hr run at 14v?). Connections seem to be good and batt's are 3 mo's old.
Any help would be greatly appreciated!!! THANK YOU!!!!
