Starting 1977 150 HP tower of power
Filippell
I have a 1977 150 HP tower of power with an external wiring harness that's not yet hooked up. Before I wire I'd like to Hotwire the ignition to make sure the engine runs. What ignition wires do I connect together to start the engine. I plan to just jump start the battery directly to the starter motor, so I'm asking only about the ignition. Thanks
GA_Boater
Welcome aboard.
Started a new topic for you. Where you posted is not related to your question and is an old, inactive thread, Please look at the Help Tip on top of the page.
Someone should be along to help soon
Chris1956
Flippell, Whereas you can "hotwire" the ignition for that motor, if one of the connections comes loose, you risk damaging the expensive ignition (switchbox and trigger) components. To hot wire it safely, you will need two battery cables with ring terminals, an ign wire with ring terminals, a charging wire with ring terminals, plus a jumper wire with alligator clips.
