Re: Starter
The compression test is simply to see if the engine is in good health. No point in beating a dead horse. Yes, I meant rope it over to test the compression if you have to.
Ok, lets say the general health is ok. A voltage drop test will isolate a high resistance in the individual part or connection being tested. Let's take the positive battery cable for instance. You would put your voltmeter leads on each end on the cable and have somebody turn the key to crank it. The voltage reading in a perfect world would be zero, but the world isn't perfect, so you are looking for something significant. A couple of volts would be quite significant, indicating somethng is amiss with that cable. You can do the same thing with each cable, connection, solenoid, etc. Just put your leads on each side of the item. Most would be zero, like battery post to battery cable lug should be zero. Remember--red meter lead always go to the side closest to the battery + post.
Across the starter motor reading would be about 12V in a perfect world. At least about 11V. That is, red lead to the cable stud, black lead to starter mount.
