starter will not turn merc 200efi
mistylady
starter will not turn engine checked fuses ok, neutral okay, next step battery. any other suggestions would be appreciated.<br /><br /> mistylady
Perfidiajoe
Re: starter will not turn merc 200efi
Does the starter make any noise at all? Take a test light, hook it to the starter terminal on the starter, & to ground, or - on the battery, hit key to start, see if the light goes on. If it don't no voltage to starter, if it does, & starter does nothing at all, starter is most likely bad. This is assuming a good battery, charge that first! If the starter engages the flywheel but does not turn, pull spark plugs & try to turn by hand. Let me know what happens, & I will try to help from there. Good luck, Joe
mistylady
found the problem you must have both batteries connected to complete the ground circut.<br /><br /> mistylady
