When I was out on the water today my engine stalled. After it stalled out I could hear a noise coming from the engine and it turned out the starter was still running. When I turned off the main switch the started did stop spinning. Main switch on and the starter came on the starter gear came up to the flywheel and when the engine started the starter gear went back down but the starter was still running. The engine has a start button. No key no ignition switch. I will test the start button but if its good how would you test a solenoid?
