starter/solenoid wiring for 2000Mercruiser 5.0L
Jime2
Can someone help me with the proper connections to the starter and solenoid on a Mercruiser 2000. I replaced this Mercury part number 50-863007A 1 - Starter, Offset Bolt Pattern. with a Sierramarine part number 18-6275 and misplaced the wiring diagramthat I drew.
Ayuh,...... Welcome Aboard,...... The bigger cables with the bigger eyes go on the big terminal of the solenoid,......
The smaller yellow/ red wire goes to the inner tiny terminal, nearest the block,......
The purple/ red little wire goes to the outboard tiny terminal,......
Jime2
Thank you much. The Bigger cables were ok. I just needed to verify which terminal I needed to put the 12 volts from the ignition switch. thanks again!
