Kiedisdog19
- Jul 30, 2013
- 14
Trying to get my 1983 Mercury 800 started. The starter spins with the key, but the Bendix will not rise when the starter spins. But I've noticed that the starter is spinning clockwise. Based on the YouTube video's I've seen (this is my first outboard), the motor runs clockwise, so the starter should run CCW. The starter spinning the wrong way would also explain why the Bendix doesn't lift. I have it wired just as the diagrams say I should.....positive battery post to the solenoid, negative battery post to the bolt on the top/side of the starter. I'm wondering if a bad solenoid or rectifier could cause this? Every connection is cleaned and tight, I have two batteries both fully charged. I've searched, and I can't seem to figure out where to go from here. Any guidance would be most appreciated.....thanks in advance.
