Starter question
granpafish
This is probably a no brainer for a lot of you. On a 93 Evinrude 50 hp, the starter is spinning but not rising to the flywheel. Is there an easy answer or is the starter shot? Thanks, Granpa
petryshyn
Re: Starter question
is the battery up in charge?<br />If so, try lubing the shaft that the starter drive rides on. Use light engine oil or WD-40<br /><br />
granpafish
Wow! Ask the schemer a question and you get an answer that even granpa can understand. Without giving away my mechanical skills, I'll tell you that a picture is worth more than a thousand words. Thanks for the the outstanding help. Granpa
oldboat1
(Great pic.) <br /><br />Clean and tighten all electrical connections in the starter circuit and at the battery, and fully charge the battery. Lightly oil the shaft, as indicated. If the gear doesn't engage after that, it may be time for a rebuild --possible the armature isn't spinning fast enough, or the bendix gear itself needs repair.
granpafish
Oldboat, thanks for the additional suggestions. So far the lube hasn't taken. As soon as the temp drops down to a breathable level, I'll go out and try cleaning the connections. Granpa
