ok i have a 460 jet boat, just put the motor in a noticed it has 2 starter points. front of bellhousing and one on the top back side, if you use the top back side do you need a reverse rotating starter? if its installed on the front it turns the motor one way and if on the back side it turns the motor the other way right???
