starter problem got worse
SPOONMAN1
95 omc 7.4 KC ---Well I knew I had starter problems because when I turned the engine over it make a revolution or two then something would bang real hard, shake the whole boat. On the lake yesterday it worked ok with the exeption of a ocasional whirring. Today someone was coming over to possibly purchase the boat and the problem is worse, so I have removed the starter and it appears fine. Flywheel appears fine . The bendix is functioning because the engine does turn over some before a bang or a whirr happens. Is it possible there is a bolt on the fly wheel sticking out and catching on something?
SPOONMAN1
Re: starter problem got worse
With closer inspection I found one tooth missing from flywheel. I will pull engine and install new one. Seloc manual says you must determin min. engine height before engine removal. What does this insure??
HT32BSX115
That probably is so you can get the engine back to the same relative position for getting the alignment right.
I strongly suggest that you get yourself a correct year/model OEM OMC service manual. Seloc is notorious for errors and omissions.
SPOONMAN1
I appreciate the info on the manual. I will still need an allignment tool though won't I ?
HT32BSX115
absolutely! Even if you weren't going to pull the engine, considering what a new coupler, u-joints etc costs, if you don't know when the alignment or bellows etc were checked last, it's good to pull the drive and check check the U-joints, bellows, and alignment anyway.
SPOONMAN1
Any suggestions on locating an alignment tool? And are they make and model specific?
HT32BSX115
You can either borrow one from any Merc dealer (if they allow it) or pick one up on ebay etc.
You can also make one if you have access to a lathe. That's what I did.
They're all pretty much the same nowadays....:
http://www.iboats.com/Marine_Store/...42404--submit.Search--submit.x.26--submit.y.7
http://www.mercstuff.com/page16.htm
http://outdriveshop.com/engine_alignment.html
http://www.sterndrive.info/id25.html
http://sterndrivetools.com/Replace your Gen II Shift Cable.html
EVEN EBAY
SPOONMAN1
well, I work at a machine shop ( I'm not a machinist) where can I get the specs for it?
HT32BSX115
I knew you were going to ask that!!
Buy one of your machinists a 6 pack and he/she will probably make it in in less than 45min!!
It took me about an hour to make mine, out of a piece of 1.375" dia steel.
Here's the picture courtesy of DonS
SPOONMAN1
you guys are great! I can have a freind @ work make this while I conentrate on building an "A" frame to pull the engine. What other maintenance or trouble areas should I look at while I have the engine out?
HT32BSX115
I'd retorque the transom plate and maybe just look at other "stuff" in there for loose fasteners etc... look closely at the coupler and splines to see how worn they are......
Even replace the bilge pump .... they're usually pretty hard to get to with the engine in there....
subcrx
got my alignment tool on ebay for 50 bucks. cant go wrong
Uraijit
Banned
Ditto, but if the guy has access to a machine shop, he'd be stupid to go buying one off Ebay. Save that money to put toward the flywheel replacement...
SPOONMAN1
95 OMC 7.4 K C ---Alignment tool made made yesterday, $000 investment. Rick suggested I get an OMC or OEM Manual instead of the seloc I have now. I have not found any online. Any suggestions? This brings up original ??? Why does the seloc manual insist on calculating "min. engine hieght" It says that that it must be checked prior to engine removal & if the dimension is less than 14" you must install exhaast elbow high rise kit. The Engine has been in for 10 years & not needed the rise kit. I don't understand how I could change the engine height by R&R.
Don S
You can't,
Engine (riser) height is determined by the manufacturer of the boat, long before you bought it.
Why Seloc makes a big deal about it, who knows.
You do realize you only have to replace the ring gear on the flywheel don't you? You do not need a complete flywheel.
http://marineengineparts.com/shopsite_sc/store/html/page91.html
SPOONMAN1
Thats what I thought --I do need a better manual. Yes, I had planned on trying to replace only the ring gear, but wasn't sure how. I assume grinder, heat & cold- tack weld, Anything tricky about it? Also I had planed on just picking one up @ the auto parts store.
Don S
Once you have the flywheel off, you can use a hammer and punch to knock the old ring off.
Then heat the new ring gear to about 450? and just drop it over the flywheel. When it cools, it will be tight.
SPOONMAN1
Thanks a bunch, I still would appreciate anyone knowing where I could find a good manual.
SPOONMAN1
Are clymer manuals about the same as seloc?
