Starter pawl adjustment
markcvl
How to adjust the starter pawl assembly on my 1995 johnson J15EEO 15 hp outboard? The water pump was replaced and I could not pull the recoil starter cord due to the starter pawl being engaged. The link to push up the pawl is short in neutral. After removing the 6 bolts from the lower section to replace the water pump a screw is loosened to separate it from the upper section. Doe's that screw and clamp assembly set how high the link to the pawl goe's? The mechanic said no but it was fine before the pump was replaced. The link to the pawl did not shrink and there is no other adjustment except for the set screw on the pawl cam which was all the way in according to the manual. Any help would be appreciated.
Thanks in advance, Mark
