Should the starter drive gear dis-engage the flywheel after stopping the power to the starter? I replaced the starter and flywheel on a 1990 Mercruiser 5.7L 260hp with a new GM flywheel and Delco starter using new starter bolts. Before reinstalling the motor back into the boat I hooked up the starter to a battery and turned over the engine with a remote starter switch, the starter engages perfectly each time I tried the starter but would not disengage from the flywheel when power was stopped to the starter. A light touch with a screw driver with no prying and the gear would dis-engage and re-nest in the starter housing. Problem or not? If so how do I fix it?
