VanillaGorilla
- Nov 4, 2003
- 32
Hey guys. I've been having an intermittent problem with my starter on my 2000 Johnson 130HP outboard. I'll put it in the water and it starts right up (usually) ... then if I run for a while (get everything nice and hot) and shut if off, it won't start. I pulled the cover, turned the key and saw that the starter gear is engaging the flywheel but won't spin the flywheel. So that tells me the solenoid is probably ok. Once, after repeated attempts to start it, the starter began to smoke. After letting the motor cool off for 15 or 20 mins, I have luckily been able to get the motor to start. I am thinking it is probably the starter motor going bad ... but don't want to make a mistake and spend $200 unless I have to. Thoughts? Thanks in advance!
