Good Morning,
I had an issue last week where when I turned my Battery Switch on, the starter immediately engaged. I turned the battery switch off, checked that the ignition switch was "off", and turned "on" the battery switch. Again, the starter cranked the engine.
I then removed the lead going to the starter solenoid, turned the battery switch on and again the starter engaged.
The motor is an AQ260.
Bad solenoid?
Thanks in advance for anyones thoughts...
Bad solenoid?
