Johnny Smith
- Sep 6, 2010
- 5
I have bought a Marada MX2 Sport Series boat. I smelled fuel in the bilge area and quickly addressed a leak from the sending unit. While closer inspecting the fuel system I noticed a non marine carb. I bought a new Holley 4 barrel from Holley. The boat initiall started after a little coaxing and ran great. It was just a test run. I turned it off at the dock. It wouldn't start when I tried to get it to the trailer. I tried starting it for a bit working the throttle until I noticed a little drag from the starter/battery. I took the boat home removed the battery and checked the charge with a load test. It was fine. I took it back to the water the next day and all I get is a hard clunk from the starter. I tried 5 or 6 times to no avail. Pulled it out of the water again and removed the starter. It tested good. I haven't pulled the plugs, but is it possible the cylinders are full of fuel? If so did I hurt anything from trying to start it? Thanks for the help. This forum is fabulous...
