Starter issues
dcouture29
I've read through other posts but can't find my specific issue. I was out on the water the other day. Went to start motor but the starter just spun and wouldn't engage. I was able to pull start the boat and drive it back to my mooring. When I got back, I tried the starter and it engaged. I started it 10 times with no issues. Pulled the batteries and checked next morning. 12.7 v. Suggestions?
Texasmark
Re: Starter issues
Clean up your wiring, all connections between the battery terminals and the starter including the red lead terminal on the starter and the starter ground to where ever the black battery lead connects. On some engines it connects right to the starter and on other it goes to the engine block with a jumper over to the starter. The strap on the starter completes the ground connection. Remove the connections, clean up with a wire brush or other suitable corrosion removal device and reconnect nice and tight. It would do well to spray the contacts when finished with the red battery contact spray that comes in the kits with the red and green treated washers. WW has the kit in the battery dept.
Your problem was dirty contacts somewhere having too much of a voltage drop. You need about 10v to spin up a starter and that's at the starter terminals when spinning the engine. With engines requiring 100 to 200 amperes to spin over, and only 2.7v in your case to spare, just about any resistance in the circuit will eat up the voltage margin.
Other thing is your bendix needs to roll freely up the shaft. Roll it up with your finger and test it. A light oil on it wouldn't hurt.
If all that gets done and you have a problem again then I would suspect that the contacts inside your starting solenoid are pitted and not allowing full current to pass meaning time for a new one.
HTH,
Mark
dcouture29
Re: Starter issues
Texas Mark, thanks for taking the time to write this lengthy response. I really appreciate it. What your saying makes complete sense. I have cleaned up all my connections from the motor to the battery, greased everything up and I'm going to see how things go. The starter connections looked good so I'm choosing to wait to see if the problem re emerges before I start disconnecting wires from the motor
Thanks again
Texasmark
Re: Starter issues
Keep us posted.
Hear you on the starter connection looking good sir, but it's where the current has to pass is what matters. They can look good on the outside and be corroded on the inside.
What you can do is put your voltmeter across the starter ground stud and hot stud, not the nut, the stud. Spin your engine, plugs in place and all just like you were going to start it, and look for 10v minimum. If you have it you're good to go.
Mark
