1998 Four winns<br />5.7 Volvo GS I-O,<br />Starter spins but bendix does not engage. Clymer indicates there is an assist solenoid. Does any one have an idea where this might be located? The exhast riser is in the middle of the manifold, and attached to the front of the riser bolts is a large plastic cover where there are two 50 amp breakers, and the connection plug from the dash plugs in.<br /><br />any help would be appreciated. I really do not want to pull the starter, because the only way to get to it is to pull the exhaust manifold off, or pull the engine
