Justinehammer
- Jul 7, 2020
- 2
Hi all.
I bought a boat this summer and have had issues since I bought it. I have had issues with the electrical and ignition and can't seem to find the culprit. I had it to the boat shop and they couldn't figure it out.
First, when starting, the engine runs and then dies. Sometimes the starter will get stuck engaged and then I have to hit it a little or disconnect the battery. Replaced the starter solenoid, didn't have that issue for a while,but boat would still run and then die. It would run as long as throttle was forward but when put in neutral, it would die. Then I had the carbs cleaned. Boat ran after that and started fine but ran at very low power and when throttle pushed forward all the way it would die out. So I replaced the fuel filter and added more premium gas. Then tried to start it and had the starter get stuck engaged a couple times. Got it unstuck. Then the last time I turned the key over it wouldn't stop trying to start up even after I pulled the key out. So I unplugged the battery. Now when I hook up negative terminal on battery, the engine tries to engage. Even tried disconnecting the ignition switch and kill switch and it still tried to engage. So it is currently unhooked and I am trying to figure out what the issue is.
