Hi all,
I just replaced my starter. The problem is that when I turn the key, the starter spins counter clockwise. This will not allow the Bendix gear to to climb up and engage the fly wheel. Also, my trim motor does not work either. Is this an indication that the solenoid that the starter is hooked to is bad. It does make a clicking/clacking noise when the key is first turned. I did a direct connect to the starter with a jumper cable and battery outside the system on both the new and old starter. They both spun counter clockwise.
I have a new ignition switch, battery is fully charged, cables are clean and tight, all wires are tightened securely. The problem showed itself on the water, which resulted in a tow back to the dock. Prior to the breakdown, there were no indications of any problems.
I have a trip planned the 8th of July, so I'm going to get the solenoid on the way with the hope it both makes it by the weekend and fixes the problem.
Thank you.
Thank you.
