scorpion264
- Aug 23, 2005
- 4
This is about my 1982 Chriscraft Scorpion 264 I/O with GM 350 Mercruiser 260 hp motor with rochester 4 brl.....Starter was replaced with new one by a certified mechanic 4 yrs ago...now when I turn my key my nothing happens. No click's no sounds..nothing. The fuse at my key is good. All gauges come on and battery power is up with switch set to all. Control is at neutral and it is the type where you push the center button in the handel to maintain the neutral position so as to be able to increase or decrease engine rpm' after starting. The starter is very hard to get to and unless you have very small hands and body you would have to partially pull the engine to be able to pull the starter. Could this be solenoid's or the control handel? How do I troubleshoot this?
