Starter Help!
YmeHP
Hello, I have just changed the starter and solenoid on my 88' Larson Senza with the 350 cu in merc. When I turn my key the starter kicks out but doesn't spin. Am I missing a wire lead, if so what color? Any other ideas, thanks!
YmeHP
Re: Starter Help!
I've got a RED from the battery, a RED/YELLOW from the solenoid, sounds like I'm missing a red from the circuit breaker, correct?
Robj
Re: Starter Help!
Does the engine turn over by hand?? If it does, check the main connection from the battery to the solenoid terminal and that it is grounded properly. If it doesn't turn over by hand, your problems are elsewhere.
Have a great day,
Rob.
