So... my first mate turned the ignition key while the motor was running... After hearing the grinding sound, key was turned the right way and engine shut down. Went to restart after anchoring for a bit and the starter would only freewheel. Can someone tell me the steps I should use to troubleshoot?
I did try jumping the solenoid, and still got only the whining/freewheeling sound from the starter. Presume I'm left with either a damaged flywheel (really bad...) or "just" stripped the teeth in the starter.
Before I pull the starter and hope that those are the teeth that are striped, anything else I should check first since I will need to be upside down and backwards trying to get the starter out...?
Thanks in advance for any advice!
