Members -
Need continued advice on bringing a new-to-me, 1975 Mercury Thunderbolt 200 (20hp - 1200225) to life. I had a thread going "advice on starter assembly" but after a week of tinkering and replacing the many tiny wave springs, friction springs and a missing part - I have the starter assembly operating (it will engage flywheel). Now to next issue...
Though the starter pawls now engage the flywheel, it is almost impossible to pull the pull cord. With both plugs in, I cannot get the engine to turnover via the pull cord. With the plugs out, the cord, flywheel and pistons seem to cycle perfectly. I believe the engine ran less than a month ago and has had regular service. I sprayed a little carb cleaner and lube in the spark plug holes and worked the cord some more, but the effort remains difficult/impossible with plugs in.
What should be my next steps???
I've already:
1. ordered a shop manual,
2. crawled these forums,
3. hit the gym 4-5 days a week so, don't infer that my physical strength is an issue.
I was told the motor has new plugs, carb rebuilt, head gasket replaced, water pump and lower unit refurbed.
I am new to 2 cylinder repair, so don't assume. Thanks in advance!
CigarXO
I've already:
CigarXO
