Starter and trim/tilt problem. Is it the control?
patrolcarr
Had problems (lag) with trim/tilt and starter. Both are situated at the throttle control. Is water or moisture the culprit? Trim/tilt worked but only if I held the button down for about 5 seconds. The engine started but only when I held the key in the "Start" position also for about 5-7 seconds. Both times I heard "clicking" noises coming from the engine before the motor and tilt/trim engaged. Any ideas??
JB
Re: Starter and trim/tilt problem. Is it the control?
Your question is answered in the Electronics and Trollers forum, PC. Please don't multiple post. It causes confusion and annoyance.<br /><br />Thanks. :)
