Re: started using a fishfinder
The best way I have found to find the depth of a lure is to test it in a swimming pool. Cranks have the depth usually somewhere on the box, and a sinking line like a heavy fluoro will increase it by one to two feet. But, with my soft plastics I cast, and count how many seconds it takes to get to the bottom of an XX foot deep pool. Then, I know almost exactly. I can fish a weightless soft plastic at more than 15 feet (and actually catch something on it
) Takes forever getting down there, but the slow falling without the weight sometimes triggers a strike.
Also, never rely solely on what people tell you. You won't catch much. I almost always go to my local lake forum, and read the reports, and sometimes ask what is working before I leave to head to the lake. But, I almost never throw the same bait, or head to the same place and such. You gotta put your own variation on things, and try your own methods. Usually works best, and is the best way to LEARN, and not FOLLOW DIRECTIONS.
As for your sonar, for a while, you need to TURN OFF the fish symbols. Then, IGNORE fish arches for the most part. You need to learn to interpret different cover and structure. Start by fishing the type of cover you know holds bass. Then, learn to interpret baitfish on there. If they are in a tight ball, you can tell they feel little threat. If they are swimming in a loose and frantic pattern, you can tell that they are being chased, and they have separated as not to become such an easy target. Then, and only then, start interpreting fish arches as bass, and trying to catch them. A local guide around here rarely tries to catch fish that he sees on sonar. He uses them to see what depth they are holding at, but rarely casts to a structure cause he sees fish in it. I feel that it was invented more to find what depth they are holding at, and for finding cover and baitfish, more than actually pinpointing a casting direction for fishing.
EDIT: I reread my post, and realized I had one major mistake in it. I for some reason typed that if baitfish are in a clump, they are being chased. Didn't mean to type that. Meant to type the opposite. When they are in a tight clump, they feel safe, and are just following each other. When they feel threatened, the scatter. Sorry for any confusion. I fixed it in the main body of the post too.
