Started Up First Rebuild. 1 Problem
fixmyevinrude
1994 Evinrude 200 HP 90 Degree Looper. This was my first rebuild and first I would like to say Thank you to everyone for all the great help. I really enjoyed doing it. Started engine on trailer with double oil and garden hose. Started fairly easy and I let it run about 5 minutes. Will try to take to water in the next few days if weather permits. The only problem I see so far is that the pressure relief valve housing is leaking. When I took this off the engine for rebuild I did not see a gasket for this or any sealer on the plastic housing. The only thing in the form of a gasket was a rubber washer in side the housing. I replaced it with a new one. I checked the BRP web site and it does not show a gasket and the shop manual was very vague (Seloc) on this. Do I have something inserted wrong or do I need to put a little gasket compound on the housing. Any help would be appreciated. HAPPY THANKSGIVING.
Eshaw150
Re: Started Up First Rebuild. 1 Problem
are u talking abot the vales under the thermostats if so where are the leaking out at little hole or around the gasket if it leaking out of the hole u may have a blockage if you replaced the rings. i just rebuilt mine and i didn;t cahange them out my thermos leakerd
fixmyevinrude
I am talking about the pressure relief or perhaps it called the blow off valve. It is between the thermostats. A hose from each thermostat runs to each side of the blow off housing. The housing is attached to the block which also has a water passage in it. The housing is leaking. As I said I remember no gasket between the housing and the block and none is shown on the BRP website. Not quite sure how it seals. Any help would be great.
mikesea
make sure where the rubber seats is clean,check rubber for creases ,dry rotmake sure the cover is not warped,you mite try swapping otherside,you can try some silicone or gasket adhesive in the round groove
