I have a 93 OMC Cobra, Ford 302. I drained the manifolds and block, then proceeded to fill all the hoses with anti-freeze. I ran into a problem when i tried to fill the hose that leads to the sterndrive, it wouldn't take any fluid. So i hooked the the muffs up to the outdrive, turned on the water, and nothing came out of the hose in the engine compartment. I then tried to backflush the system by hooking the garden hose to the hose in the engine compartment. I turned on the water, and only a trickle of water came out the outdrive. So, I gather theres a blockage. Whats the first place to check? I replaced the impeller this year and didnt see any buildup in the passages. The engine didn't overheat at all this season, it always stayed right at 150 degrees. Has anyone used some kind of chemical in the lines to clear restrictions?<br /><br /><br />BTW, the impeller that i replaced had all its fins/came out in one piece.
